Inital Prompt skipped
Jul 8th, 2008
I'm running UCCX 5.0(1)SR02ES01_Build013 and wrote a script where customers go to a queue, when all agents are busy.
Within this queue there is a initial prompt, before the caller will be taken on hold. Sometimes this initial prompt is not played and the caller is directly taken on hold.
Any ideas?
Peter
simonandorfi Tue, 07/08/2008 - 05:22
hi,
just a few ideas:
do you use HA? Have you uploaded the promt via promtManager? Are all CTI-Port registered? Does the Queue work fine?
Have you tried to set the Prompt Non-Interruptable in CRS Script?
Simon
kre8or2007 Tue, 07/08/2008 - 08:41
We had this problem on a short message, we added a few seconds of silence to the beginning of the message and it worked.
honniesr Wed, 07/09/2008 - 14:01
We had this issue (and some other "wierd" issues)... we added a delay 2 sec to the top of all our scripts to fix them.
Robert
