interoperation between cisco voice gateway and avaya PBX
Jul 8th, 2008
Kindly help, i want to integrate the CM 6.1 with avaya pbx but d pbx cant see d gateway.i have done all d neccessary. find attached dconfig
thanks
ISDN Serial0/0/0:15 interface
dsl 0, interface ISDN Switchtype = primary-qsig
**** Slave side configuration ****
L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
Layer 1 Status:
ACTIVE
Layer 2 Status:
TEI = 0, Ces = 1, SAPI = 0, State = TEI_ASSIGNED
Layer 3 Status:
0 Active Layer 3 Call(s)
Active dsl 0 CCBs = 0
The Free Channel Mask: 0xFFFF7FFF
Number of L2 Discards = 0, L2 Session ID = 11
Overall Rating: 4 (1 ratings)
pcameron Tue, 07/08/2008 - 04:20
Could be 2 possibilities -
1) The cable between the router and the PBX is incorrect. A E1 cross over cable is normally used -
1 ---- 4
2 ---- 5
4 ---- 1
5 ---- 2
2) Based on the errors below, the framing may be incorrect. Try changing to CRC4 instead of the current NO-CRC4
E1 0/0/0 is down.
Applique type is Channelized E1 - balanced
Receiver has remote alarm.
alarm-trigger is not set
Version info Firmware: 20050620, FPGA: 15, spm_count = 0
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line Primary.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (113 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
2 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
2 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 82 Unavail Secs
Total Data (last 85 15 minute intervals):
2161758 Line Code Violations, 55883 Path Code Violations,
1304 Slip Secs, 5 Fr Loss Secs, 6 Line Err Secs, 0 Degraded Mins,
1305 Errored Secs, 0 Bursty Err Secs, 6 Severely Err Secs, 49876 Unavail Secs
E1 0/0/1 is down.
Far End Block Errors Detected
Transmitter is sending remote alarm.
Receiver has loss of signal.
snzeadibe Tue, 07/08/2008 - 06:35
he E1 0/0/0 IS UP NO VIOLATION ERRor but its still not connecting.
it gives msg AWAITTING-ESTABLISHMENT
kindly help out
pcameron Tue, 07/08/2008 - 14:14
You may have a ISDN User/Network side mismatch between the gateway router and the PBX. Try the following -
clear counters
term mon
sh controllers e1
debug isdn q921
conf t
controller e1 /0/0/0
shutdown
no shutdown
exit
exit
If you see a message that includes the text "BAD FRAME" , change the ISDN operation from user side to network side. If the Gateway is H323, the way to do this is -
interface serial 0/0/0:15
isdn protocol-emulate network
If you are using CCM, go under the gateway endpoint configuration page and change from User to Network , save the settings and reset the gateway.
