IPSec output interpretation (pkts no sa)
Jul 8th, 2008
Does "pkts no sa (send)" mean that SA's are timing out too quickly? How can I mitigate this problem?
Router#sh crypto ipsec sa detail
interface: GigabitEthernet0/0
Crypto map tag: lajesvpn, local addr 208.4.63.99
protected vrf: (none)
local ident (addr/mask/prot/port): (192.168.62.61/255.255.255.255/47/0)
remote ident (addr/mask/prot/port): (192.168.62.60/255.255.255.255/47/0)
current_peer 132.30.100.20 port 500
PERMIT, flags={origin_is_acl,}
#pkts encaps: 11924940, #pkts encrypt: 11924940, #pkts digest: 11924940
#pkts decaps: 11268741, #pkts decrypt: 11268741, #pkts verify: 11268741
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 0, #pkts compr. failed: 0
#pkts not decompressed: 0, #pkts decompress failed: 0
#pkts no sa (send) 31986, #pkts invalid sa (rcv) 0 <==
#pkts encaps failed (send) 0, #pkts decaps failed (rcv) 0
#pkts invalid prot (recv) 0, #pkts verify failed: 0
#pkts invalid identity (recv) 0, #pkts invalid len (rcv) 0
#pkts replay rollover (send): 0, #pkts replay rollover (rcv) 0
##pkts replay failed (rcv): 0
#pkts internal err (send): 0, #pkts internal err (recv) 0
local crypto endpt.: 208.4.63.99, remote crypto endpt.: 132.30.100.20
path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0
current outbound spi: 0xF7E734A3(4159124643)
inbound esp sas:
spi: 0x535C185(87409029)
transform: esp-3des esp-md5-hmac ,
in use settings ={Tunnel, }
conn id: 3010, flow_id: Onboard VPN:10, crypto map: lajesvpn
sa timing: remaining key lifetime (k/sec): (4376668/1083)
IV size: 8 bytes
replay detection support: Y
Status: ACTIVE
inbound ah sas:
inbound pcp sas:
outbound esp sas:
conn id: 3021, flow_id: Onboard VPN:21, crypto map: lajesvpn
sa timing: remaining key lifetime (k/sec): (4373069/1083)
IV size: 8 bytes
Status: ACTIVE
outbound ah sas:
outbound pcp sas:
Overall Rating: 4 (2 ratings)
mchin345 Mon, 07/14/2008 - 08:35
  • Silver, 250 points or more
Use the following two commands and reinitiate the connection.
clear crypto isakmp-Clears the Phase 1 security associations.
clear crypto sa-Clears the Phase 2 security associations
santipongv Wed, 07/16/2008 - 07:16
Interestingly, the IPSec tunnel went down by itself and came back up. The statement in question no longer appears in the "sh crypto ipsec sa" command.
achrich Tue, 07/29/2008 - 02:17
we have a had the same issues since deploying a new code. ( 12.4-19.18T6) where GRE IPsec restarts tunnels after a random time period. Generating a lot of the no SA send messages.
Did you manage to get a response or fix ?
santipongv Tue, 07/29/2008 - 03:19
No, I did not get further response or fix on this issue. However, I use 12.4(17a) on the IPSec hub router and have a separate hub for GRE tunnels. I also experience the same problem where GRE tunnels restart after a random period due to EIGRP hello expired. I am currently looking into applying IP MTU and IP TCP MSS-Adjust on the Tunnel interface. I will monitor the results.
santipongv Tue, 07/29/2008 - 03:33
Currently, I have hub-and-spoke setup for both IPSec VPN and GRE Tunnel. I am not certain if this bug applies to my current setup. However, I will definitely keep this in mind when I migrate to DMVPN setup.
achrich Tue, 07/29/2008 - 03:43
yeah only applies if your using tunnel protection on your GRE i think.
