a.alekseev Tue, 07/08/2008 - 04:32
  • Gold, 750 points or more
It is replicated to Second Switch.
purohit_810 Tue, 07/08/2008 - 04:47
  • Silver, 250 points or more
Yes, It should replicate if you have configured identical password and domain.
- Dharmesh Purohit
Kevin Dorrell Tue, 07/08/2008 - 05:04
  • Green, 3000 points or more
Yes, provided:
1. There is a trunk between the switches,
2. The domain name matches,
3. The domain password (if any) matches,
4. The second switch has an equal or lower config revision than the first switch.
Kevin Dorrell
Luxembourg
Rupesh Kashyap Tue, 07/08/2008 - 05:22
Hi Kevin,
I am looking for some suggetion from your side for CCIE LAB (Routing & Switching). What is your Email ID?
Kevin Dorrell Tue, 07/08/2008 - 06:36
Sure, it sounds like Kevin dot Dorrell at pt dot lu.
But just to add ... anything we discuss should be strictly subject to the Cisco NDA (Non-Disclosure Agreement). I am quite paranoid about that.
Kevin Dorrell
Luxembourg
