3845 and NME-XD-48ES-2S-P
Answered Question
Jul 8th, 2008
I have been trying to configure a 3845 with 1 NME-XD-48ES-2S-P, it does not show the ports at all. When I do a sh diag the card is physically there and on power on the card does power up. Any ideas would be appreciated?
the IOS is c3845-advipservicesk9-mz.124-18.bin. thanks
Correct Answer by purohit_810 about 8 years 7 months ago
There is less inline power issue.
http://www.cisco.com/application/pdf/paws/71820/routermodules.pdf
See " Ethernet Switching Module " , You need to change power supply.
Dharmesh Purohit
Overall Rating: 5 (1 ratings)
littlebrook Tue, 07/08/2008 - 05:31
One last question please;
does this line "The new Cisco EtherSwitch service modules (NME-16ES-1G-P, NME-X-23ES-1G-P, NME-XD-24ES-1S-P, and NME-XD-48ES-2S-P only) are capable of providing both Cisco pre-standard and IEEE 802.3af Power over Ethernet (PoE) support when inserted in Cisco 2800 Series or 3800 Series Integrated Services Routers (requires an upgrade to an AC-IP power supply"
does this mean they will not function without the upgraded PS? it seems that it explains only that you need the upgraded PS to have the PoE capabilities?
thanks
Yvon
