CCM 6.1 7971 Changing Background Image
Answered Question
Jul 8th, 2008
How to change that image and where to upload the image, does anyone knows? thx
Correct Answer by Rob Huffman about 8 years 8 months ago
Hi Okan,
Here is a clip from the documentation;
To cache the new List.xml file, stop and start the TFTP service by using Cisco Unified Communications Manager Serviceability or disable and re-enable the Enable Caching of Constant and Bin Files at Startup TFTP service parameter (located in the Advanced Service Parameters).
Hope this helps!
Rob
Correct Answer by Jaime Valencia about 8 years 8 months ago
Overall Rating: 3.5 (2 ratings)
blackswans Thu, 07/10/2008 - 02:55
do you know which service should we restart to changes take effect, thanks
Correct Answer
Rob Huffman Thu, 07/10/2008 - 04:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Okan,
Hope this helps!
Rob
