RDBMS adding a device
dpatkins
If I want to add a new IOS router and have it authenticate using Radius (CiscoIOS/Pix6)? I will be using Action Code 220 and in V3, I will be using the VENDOR_ID_CISCO_RADIUS. Would this be the same value?
Dwane
Jagdeep Gambhir
Level 10
Level 10
Dwane,
Yes, you need to use same value "VENDOR_ID_CISCO_RADIUS".
For example:
VN = Firewall
V1 = 192.168.1.11
V2 = shared_secret
V3 = VENDOR_ID_CISCO_RADIUS
~JG
Do rate helpful posts
JG,
So this VENDOR_ID_CISCO_RADIUS correlates to the Radius (Cisco IOS/Pix 6.0)?
I will try that.
Thank you so much.
Dwane
Dwane,
Yes, that is correct.
~JG
