ASA5540 Ramdomly users of VPN client can't reach private segment.
Jul 8th, 2008
  • Bronze, 100 points or more
Hi.
I have vpn client users and ramdomly an user to get connect to the vpn but can't reach any service in the LAN.
but no happend with al users.
what i have to check ?
ozguler Tue, 07/08/2008 - 07:22
Does this users have anything in common?
Are they assigned a specific ip address for example? When u replicate the issue did you troubleshoot it? Do u see packets being encrypted / decrypted?
arturo.guzman Tue, 07/08/2008 - 07:37
i can't find the pattern of problem, last weekend the site turned off for a maintenance.
When the service return the problem began.
This ASA5540 have a failover, could be the problem the ASA Failover?
nomair_83 Tue, 07/08/2008 - 10:25
what type of failover you are using...just check sh failover and check the status
R/g
