VPN on ASA...after connection, no bytes transmitted or received?
Jul 8th, 2008
Hey all,
I set up a regular IPsec VPN connection into my work.
THe problem is once i am connected, i cant get to anything on our network. I look at the session on the ASA and no bytes are transmitted or received.
I am sure this is something small...any ideas?
Dustin
nomair_83 Tue, 07/08/2008 - 10:21
  • Bronze, 100 points or more
You mean..no bytes at show crypto ipsec sa?
If yes then enable nat traversal and sysopt permit connection ipsec.
R/g
accesshollywood2 Tue, 07/08/2008 - 11:09
oh wait...it is enabled.. im sorry.. i had a brain freeze for a minute... but.. i dont see SYSOPT permit connection ipsec
a.alekseev Tue, 07/08/2008 - 15:24
  • Gold, 750 points or more
try to add this
crypto isakmp ipsec-over-tcp port 10000
group-policy himgvpn attributes
ipsec-udp enable
crypto isakmp nat-traversal
accesshollywood2 Tue, 07/08/2008 - 15:28
I will do.. can you tell me what this does?
sorry i am still learning this stuff.. seems really complicated at times :)
Dustin
nomair_83 Wed, 07/09/2008 - 03:42
Just add crypto isakmp nat traversal 10.
accesshollywood2 Wed, 07/09/2008 - 05:40
I am getting bytes received on the ASA, but none transmitted... i think we are getting close...!!!!!!!!!!!!!
a.alekseev Wed, 07/09/2008 - 05:33
crypto isakmp ipsec-over-tcp port 10000 (IPSec over TCP, Cisco's proprietary, by default uses TCP port 10000)
ipsec-udp enable (IPSec over UDP, Cisco's proprietary, force the other side, if it supports, do IPSec over UDP, by default uses UDP port 10000)
crypto isakmp nat-traversal (NAT-T, RFC standard, take preference over "ipsec-udp enable". If both peers support NAT-T and NAT was detected in isakmp phase MM3/MM4, they will use IPSec over UDP with port 4500)
