Cuspa.vbs wont execute
Jul 8th, 2008
I am trying to upgrade my Unity 4.2(1) and when I double-click the Cuspa.vbs file, nothing happens, at all. There are no application or system log reports, CSA is disabled. What might this be?
Christopher McAlpin Tue, 07/08/2008 - 10:49
If you are running CUSPA on Windows 2003, from a network location, you may need to add the network location to Internet Explorers Local intranet or Trusted Sites security zone.
IE --> Tools --> Internet Options --> Security
swensonj Tue, 07/08/2008 - 10:57
Hmm silly me, I forgot the rest of it.
I am running on a local session and it is Windows 2000 5.00.2195 sp4, Iexplore 6.0.28.
MS Script host says it is apparantly installed but I fear not working properly.
tsteger1 Tue, 07/08/2008 - 11:41
Try opening a command window and running:
wscript Cuspa.vbs
This should give you an indication if it is running and/or display any messages
You might need to run it in Cscript mode.
If so, run this in a command window.
cscript Cuspa.vbs
swensonj Tue, 07/08/2008 - 12:06
It does run, with no output. I stepped through it, this old debugger doesn't make it very easy to watch what happens to data in a process. Checking manually I see that it is not creating directories or copying files, then exiting on matching:
If IsDrvVolatile (Left(strScriptPath,2)) Then
tsteger1 Thu, 07/10/2008 - 13:38
The only other suggestion I can think of is to force cscript to run it.
There may be some commands incompatible with wscript (not having the script, I cannot say).
Have you tried running other scripts on this server or running this script on another server?
