Warning message
VPN working on XP, but not on Vista
Jul 8th, 2008
I've been building a VPN configuration to allow Windows Clients using the Windows VPN Client to access our internal LAN. Well, it comes out I didn't do a good job.
The VPN connection is working perfectly fine as long as XP clients are used. As soon as a Vista client tries to connect, it doesn't even get past the "Connecting to -IP-" stage (actually it asks me for a password and username, but I guess that's right at the beginning).
I am posting the relevant parts for my configuration here. I am using PAT for translating entries and I am using a Cisco 1811.
Thank you for your help
-snip-
r#show run
Building configuration...
Current configuration : 3483 bytes
version 12.4
hostname r
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
aaa new-model
aaa authentication ppp VpdnAuth local
aaa session-id common
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.200 192.168.0.240
ip dhcp excluded-address 192.168.0.1 192.168.0.100
ip dhcp pool XXXXXXXXX
network 192.168.0.0 255.255.255.0
default-router 129.168.0.1
dns-server 192.168.0.1
ip dhcp pool XXXXXXXXXX
network 192.168.9.0 255.255.255.0
default-router 192.168.9.1
dns-server 192.168.9.1
ip domain name XXXXXXXXXX
ip name-server XXXXXXXXXX
vpdn enable
vpdn-group L2TP
! Default L2TP VPDN group
description VPDN Group for L2TP/IPSec Clients
accept-dialin
protocol l2tp
virtual-template 2
no l2tp tunnel authentication
username -removed-
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto isakmp key XXXXXXXX address 0.0.0.0 0.0.0.0
crypto ipsec transform-set MsIPSec esp-3des esp-md5-hmac
mode transport
crypto dynamic-map MsDynMap 1
set nat demux
set transform-set MsIPSec
crypto map IPSecIsaPmpMap 6000 ipsec-isakmp dynamic MsDynMap
interface Loopback2
ip address 192.168.3.1 255.255.255.255
interface FastEthernet0
ip address 78.X.X.2 255.255.255.248
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
switchport access vlan 999
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface FastEthernet9
interface Virtual-Template2
ip unnumbered Loopback2
peer default ip address pool IPSecPool
ppp encrypt mppe 128 required
ppp authentication ms-chap-v2 VpdnAuth
interface Vlan1
ip address 192.168.0.1 255.255.255.0
ip nat inside
interface Vlan9
ip address 192.168.9.1 255.255.255.0
ip nat inside
interface Async1
no ip address
encapsulation slip
ip local pool IPSecPool 192.168.3.2 192.168.3.10
ip route 0.0.0.0 0.0.0.0 XXXXXXXXXXX
ip dns server
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
ip nat inside source list 2 interface FastEthernet0 overload
ip nat inside source static tcp 192.168.0.96 22 interface FastEthernet0 XXXXXXX
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 2 permit 192.168.9.0 0.0.0.255
access-list 3 permit XXXXXXXXXXX
access-list 3 permit 192.168.0.0 0.0.0.255
-snip-
purohit_810 Wed, 07/09/2008 - 19:57
  • Silver, 250 points or more
Which version VPN client are you using?
For windows Vista you should have 5.X client, can you check more in detail or in SDM, Do you have Client Version permit/deny rule?
Check the detailed protcol, TCP 500 or UDP 10000 it tries to connect.
Tharnks,
Dharmesh Purohit
thomaslinder Wed, 07/09/2008 - 20:52
Hi Dharmesh Purohit
I am sorry, I forgot to say that I am trying to use the Windows integrated VPN Client (not the one from Cisco). As I said - it is working in Windows XP just fine, but Vista Clients appear to have problems.
I didn't configure it using SDM. How could I best debug vpn connection tries?
Thank you so far.
