07-08-2008 01:34 PM - edited 03-15-2019 11:49 AM
Generic IE Popup windows says "Error No." when updating or creating new template, or importing csv. CM 4.2.3
Anyone seen this before?
Solved! Go to Solution.
07-08-2008 03:08 PM
I am pretty sure someone here had that problem, and uninstalling/reinstalling the Bat tool on the CM cleared it up.
Mary Beth
07-08-2008 03:08 PM
Mary Beth
07-08-2008 03:19 PM
Also, while I am sure that in our case an uninstall/reinstall cleared it up, here is a link to a discussion where weveral people actually had to install an ES to get a different version of BAT:
BAT 5.1(4)through 4c was trouble, 5.1(4d) was fine.
Mary Beth
07-09-2008 05:42 AM
Indeed. Reinstalling BAT fixed the problem. Thanks
07-14-2008 11:08 AM
Do all of the templates remain in BAT after you uninstall and reload?
07-14-2008 12:00 PM
Yes, apparently reinstalling BAT installed a newer version. The templates tell me to click on it, make your changes, and then update to save in the new format.
