vlan discrepancy
Jul 8th, 2008
We have a cisco 2950-12 switch that is owned and managed by our ISP. We were told that port 1 is VLAN520 and set to full/100.
We plug our own cisco 2950-48 switch from port 32 to that port 1 using a X-over cable.
I then proceeded to define an ip address for vlan520 on our switch:
config t
int vlan520
ip address 172.17.193.12 255.255.255.0
exit
ip default-gateway 172.17.193.1
and also set port 32 to vlan520 and full/100.
int fasteth0/32
switchport access vlan520
speed 100
duplex full
Port 32 starts to blink amber and I can't ping anything.
But once I did a "no switchport mode vlan 520" on port 32, it starts to blink green and i can ping.
So is it safe to say that my ISP has misinformed me about port 1 on the 2950-12, ie, it should be vlan 1, not vlan 520?
srue Tue, 07/08/2008 - 14:28
  • Blue, 1500 points or more
maybe your isp has cdp turned on and you can get some insight into how they're configured that way.
on your 2950:
show cdp nei detail
support.edm Tue, 07/08/2008 - 15:01
Switch#sh cdp nei detail
Switch#
Doesn't give me any resulsts when I do this on our 2950-48?
