Max number of LACP channels on Cat3750G
Jul 8th, 2008
Hi all
I just wanted to know what is the max number of LACP channels that can be configured on a Cat3750G-24TS-1U switch? Tried looking on the net but can't find one. Thank you.
muca Tue, 07/08/2008 - 17:56
A set of up to 16 potential links can be defined for each EtherChannel. Through LACP, a switch selects up to eight of these having the lowest port priorities as active EtherChannel links at any given time. The other links are
placed in a standby state and will be enabled in the EtherChannel if one of the active links goes down.
vincent-n Tue, 07/08/2008 - 19:35
Wow, this is what I call a classic case of ... 'over engineering' up to 16 ports in a port channel.
Anyway, thanks for the answer but it's not what I'm after. I'm after how many port channels that I can configure on the switch, NOT the number of members in a port channel.
Here's another question, asssume that the max number of LACP channels has been reached, can I add more channels using other technologies such as PAgP? If the answer is YES then I wonder how many PAgP channels I can have on the switch. Thank you.
glen.grant Wed, 07/09/2008 - 04:04
  • Purple, 4500 points or more
Maximum total is 12 per box according to the doc I saw. Also saw a blurb about 48 per stack.
