07-08-2008 05:32 PM
I'm trying to connect this GBIC to 6km, with SMF, as you can see here:
SMF (Core Size) Micro says 9/10, I only found one fiber that cover IEEE 802.3z at 5km, Belden with part number: M9W384, but it says: Micro 8/125.
Do you know If they can work together ?.
They have the same NM: 1300.
Thank you.
07-08-2008 06:32 PM
There should be no problem connecting two WS-G5486 GBICs across 6km of Belden M9W384 SMF cable. IEEE 802.3z spec is 5km but most manufacturer's GBICs will work to 10km.
Per Cisco data sheet: CISCO 1000BASE-LX/LH GBIC
The Cisco 1000BASE-LX/LH GBIC (WS-G5486) fully complies with the IEEE 802.3z 1000BASE-LX standard. However, its higher optical quality allows it to reach 6.2 miles (10 kilometers) over single-mode fiber (SMF), compared with the 3.1 miles (5 km) specified in the standard.
Hope this helps!
07-28-2008 04:50 PM
If core size of fiber change from 9/10 micron to 8 micron, distance will not come down so much.
Vendors use some values to calculate distance see if ur fiber chords are good then distances can be more than they give.
WS-G5486 (GBIC) module can have power from -3 to -11.5 dBm. Check the optical power output of your GBIC may be u r the lucky one to get higher value than normal power from GBIC module.
