1841 series router Power supply issue
Jul 8th, 2008
It's 1841 series router, however, when do show environment, we see 'ILP power supply -absent' message, checked another same 1841 router, there is no 'ILP Power Supply -Absent' message.
GIEESAS#sh envir
Fan 1 Running sucessfully
ILP Power Supply -Absent <<<<<<
GIEESAS#
Checked cisco website, that Cisco 1841 router do not support Cisco product-based inline power,or Power over Ethernet (PoE). May i know what the ILP Power Supply -Absent' come from?
Thank You,
Overall Rating: 4 (1 ratings)
Richard Burts Wed, 07/09/2008 - 06:44
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Trina
I do not know for certain but my best guess is that certain versions of code for the 1841 (more recent ones from my quick test) generate this message. I would guess that this change was made in IOS to support the 1861 which does have support for Power over Ethernet.
I would guess that your 1841 routers that do not generate this message are running older versions of code.
Rick
