Re : Configuring a terminal server on a 2821 router .....
Jul 8th, 2008
I am configuring a 2821 router as a terminal server but somehow I could not access the console ports on the router. In this case, on R1.
Below are the basic configuration on the 2811 as the access router.
ip host R1 2001
interface Loopback1
ip address
line con 0
transport input all
line 1 16
When I try connecting to the R1 router from the access-server, I get
the error message 'remote host refused connection'.
Has anyone encountered any similar issues like this before ?
Pls advice,
- sn -
Mark Yeates Tue, 07/08/2008 - 19:02
Assuming you don't have an ACL you will want to add the login command under your line VTY. I'm not sure how you want to control passwords for your router, but you can specify one there also. Here is an example below.
line vty 0 15
password (password)
