Call forward
Jul 8th, 2008
When the IP phone is ringing and not taking the call , the call should be forwarded to the Mobile phone using call forward option(done).If the Mobile#1 too is not attending the call it should be forwarded to second mobile phone.Is there any option for this in Call manager?
Krishna Mohan
Jaime Valencia Tue, 07/08/2008 - 20:34
at that point the call has already been extended to the mobile so CCM does not have control over what happens next
if this helps, please rate
Keith Fulcher Tue, 07/08/2008 - 23:40
Exactly, As soon as the Mobile Device has been given the call the CUCM is out of the picture. You should check with your provider if there is a way to do it on the Mobile side.
chris.mann Wed, 07/09/2008 - 05:58
You could look into some of the options available with Mobility Manager, depending on your call manager version.
Jaime Valencia Thu, 07/10/2008 - 05:30
unified mobility requires a separate server on 5.x, it's integrated in 6.x
