How can my company be a Cisco Partner?
Jul 8th, 2008
I had currently get the CCNA certification. But how do my company be a Cisco Partner??
What are the other criteria that I need to achieve?
Overall Rating: 4.5 (4 ratings)
tim.giles Tue, 09/16/2008 - 07:14
I work for a Cisco gold partner.
There are a variety of factors determining whether you can be a Cisco partner but generally if you purchase directly from Cisco it helps as well as having a degree of expertise within the company. It's basically reward for loyalty to Cisco!
Usually bigger companies have the Gold status as they specialise, and have a broad range of skills in the four main areas, Unified Communications, Routing and Switching, Security, and Wireless LAN.
Hope this helps...
Please rate useful posts...
