a.alekseev Tue, 07/08/2008 - 23:44
  • Gold, 750 points or more
ena sec xxx
line vty 0 4
pass www
login
transport input telnet
logg sync
michael.leblanc Wed, 07/09/2008 - 06:49
  • Silver, 250 points or more
If you want, you could supplement Aleksey's configuration with the following to restrict Telnet access to a specific management station, and establish an idle timeout on the VTY lines:
access-list 100 remark --- VTY access from Network Management Station.
access-list 100 permit tcp host 192.168.100.20 any eq 23 log
access-list 100 deny ip any any log
Note: Replace 192.168.100.20 with the address of your management station.
Note: TCP port 23 above, is the Telnet port.
Edit: Make sure you use a different ACL number if 100 is already in use.
line vty 0 4
access-class 100 in
exec-timeout 9 0
Your interface ACL (if implemented) will also need to accommodate inbound Telnet.
mohammedmahmoud Thu, 07/10/2008 - 03:41
  • Green, 3000 points or more
To try and summarize the whole story.
Access control can be done in 4 fashions:
1. No kind of security, using "no login" under the VTYs, this will enable you to login without any kind of passwords.
2. Just use VTY and enable passwords.
3. Use local usernames and passwords on the router.
4. Use AAA.
The second case is easy:
enable secret xxxx
line vty 0 4
login
password xxxxx
The third case:
username xxxx password xxxx
enable secret xxxx
line vty 0 4
login local
The fourth case see AAA.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7a7.html
NOTE We can use an access-class to restrict the access over the VTY using an ACL, as Michael has illustrated.
Another important thing to take care of, if no enable password is enabled then you can never go to enable mode (unlike console, where you can go in without having an enable password). If neither the enable password command nor the enable secret command is configured, and if there is a line password configured for the console, the console line password will serve as the enable password for all VTY (Telnet and Secure Shell [SSH]) sessions.
I hope that i've been informative.
BR,
Mohammed Mahmoud.
olakunle06 Thu, 07/10/2008 - 07:49
please i have configured the telnet access on both routers now,but i could only telnet from router 2 to 1 and cannot telnet from 1 to 2. pls can anyone suggest what went wrong and the solution
michael.leblanc Thu, 07/10/2008 - 10:53
You've not indicated "which" commands you implemented, whether ACLs are implemented, or anything related to your network topology.
You need to be more informative if you want assistance.
olakunle06 Thu, 07/10/2008 - 11:36
ena sec xxx
i used the command above and ik cant access from R1 to R2 but could telnet from R2 to R1
line vty 0 4
pass www
login
logg sync
johnlloyd_13 Tue, 08/12/2008 - 03:02
  • Blue, 1500 points or more
you can also add service password-encryption and enable secret global config commands for security reasons..
