NAM Scheduled Caprture
Answered Question
Jul 8th, 2008
Is it possible to schedule a conversation capture between two hosts or VLAN? And how is it done.
thank you very much.
Correct Answer by Joe Clarke about 8 years 7 months ago
No, this is not possible. This was requested a long time ago in CSCed88137, but it has not yet been implemented.
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 07/09/2008 - 08:07
You can trigger a capture by going to Capture > Buffers. You should see an Automatic_Capture buffer. Click on the "NAM Alarm" link to configure a capture alarm. Create a new Network Layer Conversation alarm for the variable you want (probably bytes). Configure the various alarm options (i.e. src and dst addresses), then set a rising threshold. This could be small if you want to see all the traffic. The check the radio button to start a capture.
jonix.niebla Wed, 07/09/2008 - 19:28
Thank you very much.
Is it possible to set specific time that the capture would be triggered, say 0100H and would last for 5mins?
thanks again..
Correct Answer
Joe Clarke Thu, 07/10/2008 - 06:41
jonix.niebla Thu, 07/10/2008 - 18:40
Thanks a lot, hopefully this could be implemented soon... This feature I think should be present on NAMs.
