Error when trying to configure QOS on interface
Jul 9th, 2008
Folks,
I received this error when trying to configure service policy out from interface.
Router(config)#int fa3/4
Router(config-if)#service-policy output SETDSCP
QoS: FastEthernet3/4 doesn't support policy SETDSCP for class VOICE in Out direction
router(config-if)#
Nagendra Kumar ... Wed, 07/09/2008 - 04:03
This message is thrown if the policy is not supported in out direction.
Can you let us know which platform it is?. Also it would be better if you can paste the policy-map, class-map config.
Nagendra
pcameron Wed, 07/09/2008 - 06:13
Could be related to this -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/qos.html#wp1720400
Policers can act on ingress traffic per-port or per-VLAN. With a PFC3, for egress traffic, the policers can act per-VLAN only
You will have to give us a bit more information about platform/IOS versions etc ... if you want a more detailed answer.
