VPN client save password issue
Jul 9th, 2008
Very often when save password option is enabled in RA VPN configuration, and correct password is saved after previous login, when attempt to connect is made, Cisco VPN Client doesn't connect and shows an error "Reason 413: User authentication failed". Cisco VPN Client version 5.0.00.0340. The same issue was present with 4.8 version.
owillins Tue, 07/15/2008 - 13:58
  • Silver, 250 points or more
In order to resolve this issue, increase the value for simultaneous logins.
Choose ASDM and then Configuration > VPN > Group policy. Choose Group > Edit > General and remove the inherit checkbox for Simultaneous Logins. Choose the appropriate value. If you try more than three client connections again, it should work now.
