Multicast Null Flag !!
Answered Question
Jul 9th, 2008
Hi every1, i was playing with PIM-SM, i am not going into the detail of my network but just showing you the output i want you guys to check.
R3#sh ip mroute
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 225.5.5.5), 00:07:55/00:03:28, RP 10.1.4.4, flags: SJC
Incoming interface: Serial0/1, RPF nbr 12.0.0.1
Outgoing interface list:
Ethernet1/0, Forward/Sparse, 00:07:55/00:03:28
(20.0.0.1, 225.5.5.5), 00:00:20/00:02:39, flags:
Incoming interface: Serial0/0, RPF nbr 0.0.0.0
Ethernet1/0, Forward/Sparse, 00:00:20/00:03:28
(*, 224.0.1.40), 00:07:59/00:03:27, RP 10.1.4.4, flags: SJCL
Ethernet1/0, Forward/Sparse, 00:07:53/00:03:27
Serial0/0, Forward/Sparse, 00:07:59/00:01:57
Kindly look for this statement
Why there is no flag set ?? let me tell you that R3 is connected to a multicast client directly on its lan interface and when i tested my multicast network, client was able to get it successfully, but i am confused why no flag is set ?
am i missing something here ???
Correct Answer by Harold Ritter about 8 years 11 months ago
Ovais,
You can use the mtrace command from the router connected to the receiver to find out to trace back to the source.
Overall Rating: 5 (1 ratings)
illusion_rox Wed, 07/09/2008 - 02:48
Guys, its done, i was missing a config :-), but it was an interesting observation, no flag, no rpf neighbour but still multicast was successful :)
Kevin Dorrell Wed, 07/09/2008 - 02:57
  • Green, 3000 points or more
What exactly was missing from the config? (So I can add it in my experience bank.)
Kevin Dorrell
Luxembourg
illusion_rox Wed, 07/09/2008 - 19:21
Dear Kevin, actually on the SPT path, pim sparse wasnt enable, so thats why i was experiencing this issue, and 1 thing more, even after that i was seeing 2 flags against the same entry, "JT", can some 1 tell me how will you guys interpret this flag, T means that the router has switched over to SPT, whereas J means that its joining the SPT right ? how can they come both at the same time ?, i am really getting confused regarding the different flag combination, i referred to Beau famous book and no doubt its a great book but this area is really confusing me, does cisco gives any detail inside on what different combinations of flags mean ? ( any cisco doc ?? )
Kindly help me out in this.
Harold Ritter Wed, 07/09/2008 - 06:20
  • Cisco Employee,
Ovais,
The mcast stream was simply forwarded down the shared tree as the source tree entry was imcomplete.
illusion_rox Wed, 07/09/2008 - 19:22
Dear Hritter, can you tell me how to trace the multicast packet like we do for unicast packets ? i want to see that how it was going through the shared tree !
Thanks in advance and for clearing my confusion :)
Correct Answer
Harold Ritter Thu, 07/10/2008 - 09:57
  • Cisco Employee,
Ovais,
