Cisco ASA 5505 - NAT over a VPN
rhh_bytron
Dear all,
I've been trying to configure a Cisco ASA 5505 to connect to a remote VPN. Once connected all traffic should then present itself from one IP over the VPN using NAT. I have two VLANs called inside and outside. The inside IP is 192.168.20.0/24, the outside is 217.XX.XX.XX. NAT is enable but refuses to work over the VPN. The ASA5505 trace path facility shows the VPN thinks itx exempt from the NAT rule, why?
I want all traffic to present itself as 192.168.20.210.
I would also like to say I know next nothing about Cisco routers. This is the first one I've configured; therefore, some of my settings may be way off the mark.
a.alekseev
Level 7
Level 7
you have "vpnclient mode network-extension-mode"
use instead "vpnclient mode client"
I have made the change, but my VPN traffic still has the wrong NAT IP.
ggilbert
Just like the previous person said, you can use vpnclient mode as client and turn of NEM. But here is the issue.
You have to assign a different address pool to the EzVPN client (in this case your ASA 5505) not the same as its internal network. So, it should be something like 192.168.10.x.
Rate this post if it helps.
Apologies, but I made a mistake on my first post.
The VPN connects to a server and gets assigned an IP of 172.18.234.225. This IP differs from my inside and outside interfaces. I have been asked to ensure all traffic down the VPN is NAT'd, using 172.18.234.225 as the NAT address. The tech guys of the VPN server I connect to keep saying that my IP is showing as 192.168.20.XXX (My internal address); hence, all my traffic is blocked by their system.
The NAT line someone suggested is:
static (inside,outside) 172.18.234.225 192.168.20.XXX netmask 255.255.255.255
Although, when I run the following command:
show vpnclient detail
I get the following
LOCAL CONFIGURATION
vpnclient server 193.XX.XX.XX
vpnclient mode client-mode
vpnclient vpngroup GROUP1 password ********
vpnclient username GROUP password ********
vpnclient enable
MISCELLANEOUS INFORMATION
- Key exchange is based on Pre-Shared Key
- Traffic from, or through Cisco Easy VPN Remote will initiate a connection
attempt.
STORED POLICY
Secure Unit Authentication Enabled : Policy not stored
Split Tunnel Networks : None
Backup Servers : None
RELATED CONFIGURATION
nat (inside) 0 access-list _vpnc_nwp_acl
access-list _vpnc_nwp_acl extended permit ip any any
aaa authentication match _vpnc_nwp_acl inside _vpnc_nwp_server
aaa authentication match _vpnc_nwp_acl _internal_loopback _vpnc_nwp_server
crypto ipsec transform-set _vpnc_tset_1 esp-aes-256 esp-sha-hmac
crypto ipsec transform-set _vpnc_tset_2 esp-aes-256 esp-md5-hmac
The line that concerns me is:
I believe that is saying my VPN traffic bypasses the NAT rules. This line does not show when I run show run.
