How WAN Interfaces Handle Ping's
Jul 9th, 2008
could someone please explain the following to help me understand how it works??
I have 2 routers connected via a serial p2p link and configured with /30 ip's at both ends. If I connect to 1 router and ping its own local WAN interface, the ping request actually traverses the wan link to the B end and returns instead of just going internally directly to the wan interface. If I ping an ip on the remote router, the avg response time is say 90ms however if I ping the local wan interface the avg response time is about double at 180ms. I switched debugging on on this interface and confirmed it to be correct.
Any feedback would be helpful??
a.alekseev Wed, 07/09/2008 - 03:18
  • Gold, 750 points or more
Yes, this is a common behaviour for WAN interfaces.
Ping for local WAN interfaces goes through remote side.
edsantos1 Wed, 07/09/2008 - 03:21
is it only for WAN interfaces?? and is it for all types of WAN interfaces??
a.alekseev Wed, 07/09/2008 - 03:26
ppp, frame-relay, hdlc...
sdoremus33 Wed, 07/09/2008 - 18:37
  • Bronze, 100 points or more
Every time a hop traverses a router in its path = response time also the ttl is decremented by 1 every time a hop traversed through a router
Ex rtra --> rtrb+rtrc+rtrd-->rtrd
rtra 2 hops ttl decremented by 2
