Edit IP address on 7911
Jul 9th, 2008
When i navigate to network settings->ip address there's no edit button displayed. When i press " * * # " The "EDIT" button appears, but it's grayed (disabled). How to enable it? Thank you.
Overall Rating: 5 (2 ratings)
Paolo Bevilacqua Wed, 07/09/2008 - 03:26
Set DHCP off in the same menu. You should then be able to configure IP address.
Please rate post if it helps!
ramboza2006 Wed, 07/09/2008 - 03:53
Sorry, found the solution myself. You should disable dhcp from the same menu before the edit button becomes enabled.
