CDR size? what's the normal size?
Jul 9th, 2008
I have problems that depends of CDR file size. CDR ldf is about 7 Gb size. Where can I read about requirements about size of CDR database and how can I resolve this problem?
tim.giles Wed, 07/09/2008 - 04:03
  • Silver, 250 points or more
Attached is a document about shrinking the database which I think will help you...
Please rate if useful.....
Jaime Valencia Wed, 07/09/2008 - 06:54
  • Cisco Employee,
  • Hall of Fame,
    2011
CDR data should have a fixed size of 5GB and should not grow any larger than that, you can try deleting some records thru CAR
javalenc
if this helps, please rate
webstd.design Fri, 07/11/2008 - 03:14
And how I should save the capacity of CDR database about 5 Gb?
