Ping a Serial Interface on a 3845 router
Jul 9th, 2008
Currently I'm using 2x3845 routers with 4x 16 port SSC cards. Each serial interface is set-up with an IP address and a peer IP address. (Please see attach configuration).
I log into the router using a Linux laptop. I'm unable to ping the serial IP address, however I can ping the peer IP address. Each serial interface is set with PPP enable. My question why can I ping the serial interface IP address?
mahmoodmkl Wed, 07/09/2008 - 04:47
  • Gold, 750 points or more
There is a access-list which is denying all the traffic under u r serial interface.
Remove it and try if u can.
Mahmood
drking0414 Wed, 07/09/2008 - 05:33
R U talking removing the following statement "access-list 101 deny ip any any" from the access list? This was the very first thing I did and I still do not have any luck.
a.alekseev Wed, 07/09/2008 - 04:52
It depends not only on your stetting but it also depends on the settings on the another side.
ping for localWAN intefaces always travels through remote end.
Kevin Dorrell Wed, 07/09/2008 - 05:17
  • Green, 3000 points or more
This, unfortunately, is one of the inherent behaviors of a PPP link. You can ping the peer address but not your own.
Kevin Dorrell
Luxembourg
drking0414 Wed, 07/09/2008 - 05:35
Can you point me to a "DOC" or "RFC" that will help explain this to my peers?
