Call forward + internal external numbers
Jul 9th, 2008
Hi to all!
My question is:
I need to configure for my operator one call forwarding to one dn for external calls and another call forwarding to other dn for internal calls.
Could anyone here tell me how to set up this, if possible?
Thank you very much in advance.
Jaime Valencia Wed, 07/09/2008 - 07:33
  • Cisco Employee,
  • Hall of Fame,
    2011
you do not mention what you're using (CUCM or CME, please do so in the future) so i will assume this is CUCM and the answer is yes you can, that's the whole point of having an internal and an external CF options, have you looked at the line settings??? i'd say they're pretty straightforward on that matter.
javalenc
if this helps, please rate
uosambela Wed, 07/09/2008 - 21:54
Hi javalenc!
First of all I'm sorry for not telling what i'm using.
I'm using CME ios ver. 12.4(15).T3
telephony-service ver. 4.1
Hope it helps.
Thanks in advance.
