Cisco univercd question - OSPF in 12.2
Jul 9th, 2008
I am trying access the Cisco IOS IP Configuration Guide, Release 12.2 to obtain information about OSPF configuration http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/fipr_c.html
but being fairly new to using the univercd I am seeing something that doesn't make sense and was curious if others have seen the same thing...and may know what is happening.
I ended up looking for OSPF configuration help at this document because I was referred to it by another document.
Two things stick out...first there is no "Part 1:" listed, which is curious but unrelated to missing OSPF.
Second, the "Part 2: IP Routing Protocols" section has nothing listed for Configuring OSPF.....where did it go? Is it being edited and will show up here again in the future? Is it gone for good...if so, why is there no reference to where to look for it?
I can find configuring OSPF info in 12.1 and 12.0, but if Cisco documentation is referring me to the 12.2 Guide, I'm a bit confused.
Thanks!
