411 Local PRI routing/translation pattern setup
Jaime Valencia Wed, 07/09/2008 - 07:30
create 2 411 route patterns on different partitions and then configure the CSS of devices accordingly. if you create partition HQ and BR. make sure phones at HQ can only reach the 411 at HQ partition and same thing for BR phones.
a translation pattern also contains a CSS so use it accordingly to your needs
if this helps, please rate
Paolo Bevilacqua Wed, 07/09/2008 - 09:52
Since you're there, if you've a cue, you could setup a custom script to prompt ask which service is desired, and transfers to like 412 and 413 to route off the proper trunk, you would then translate back to 411.
This to avoid informing users of the specific number to use, thing that they would probably forget all the time.
