VPN with Dynamic IP
Jul 9th, 2008
I have two routers 1841 and 851 . 1841 has a Static Ip where is 851 is on DHCP i want to created VPN connection between the specified routers, specify me a proper wan and link to perform the specified task using SDM
Overall Rating: 5 (1 ratings)
Farrukh Haroon Wed, 07/09/2008 - 10:33
Hello Imran
Nobody will be able to suggest you a WAN link without knowing 'what' applications you want to run over this VPN. Here are some helpful links:
Please rate helpful posts.
Timpan2004 Wed, 07/30/2008 - 09:04
I have similar issues, basiclly I need to config site2site vpn tunnels between ASA 5520(server side) and ASA 5505 (client side), the client side is using DHCP'd IP's. what do I need to do in proper DDNS support for this case?
any suggestions/help are appreciated.
Farrukh Haroon Wed, 07/30/2008 - 18:21
Whatever the client uses does not matter. The server does not need to know the IP of the client before hand (but the reverse is not true, the client needs to know the IP of the server to connect).
