IP Communicator 2.1 - Change the HTTP port of the phone
scostigan2
I can not seem to find where I can change the default port 80 that the soft phone uses.
Jaime Valencia
unfortunately you cannot change it, at most you can disable it
CIPC interferes and conflicts with the web server installed on the PC
http://www.ciscotaccc.com/kaidara-advisor/voice/showcase?case=K54967101
see the note inside the link
javalenc
if this helps, please rate
java
