CiscoWorks ASA5520 and PIX 515-E device type unknow
Jul 9th, 2008
I would like to managed ASA5520, ASA5540 and PIX515-E with my ciscoworks LMS 3.0.1, but the device type are unknow in DCR Device management.
In attach you can see the output word file with the version install.
I will just save the configuration in RME and Use CiscoView for these product. For the PIX CiscoView work correctly.
Have you any solution to resolve this ?
Herve
Joe Clarke Wed, 07/09/2008 - 11:25
There is no ASA CiscoView package. You should use ASDM to graphically manage the ASA devices. As for RME support, if you go to Common Services > Software Center > Device Update, and download all of the available RME and Common Services updates, you should have configuration support in RME for all ASA and PIX devices.
rherve Thu, 07/10/2008 - 05:14
Thanks for your quick reply, it's seems to be OK. I can managed the PIX and ASA configuration in CiscoWorks.
Best regards
Herve
