NAC OOB VG mode IPPhone resetting
Jul 9th, 2008
I'm deploying an OOB VG demo environment, I have been able to go through all the NAC proces with a laptop directly connected to a switchport, but I'm Having problems when I connect via an IP Phone. It seems that when the mac notification of the PC is sent, the ipphone automatically restarts.
I have added the phones mac address to the list of certified devices, I checked the "change vlan according to global device filter list"
I'm also sure the "bounce port ..." optios are unchecked all this from the port profile, I'm still not sure why the phone resets.
Any help is appreciated.
Thanks in advance.
Overall Rating: 3 (1 ratings)
grant.maynard Thu, 07/17/2008 - 13:51
what you've done sounds correct. You have the phone on the "voice vlan" in the switch config? If so, CCA shouldn't touch the phone or voice vlan. At what point in the process does the phone reset?
