Cannot ping out of my switch
Jul 9th, 2008
Hi everyone, i'm having a problem with a network in my simulator, i have network with a router making 2 subnets, every subnet have a switch. The problem is i cannot ping from a pc to the router, doesn't reach the router, only the switch.
The simulator says that there's "No communication protocol is presente for router 2600.A protocol needs to be present that allows communication to take place. You need either default/static routes established, RIP running, or IGRP running."
The router active configuration (my subnets are in the FastEthernet ports)(Cisco 2600) :
Router(config)#show running-config
% Invalid input detected at '^' marker.
Router(config)#exit
Router#show running-config
Building configuration...
Current configuration : 625 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
ip subnet-zero
interface FastEthernet0/0
ip address 10.87.200.1 255.255.255.0
no ip directed-broadcast
interface Serial0/0
ip address 10.82.15.2 255.255.255.0
interface FastEthernet0/1
ip address 10.87.201.1 255.255.255.0
interface Serial0/1
ip address 10.82.73.2 255.255.255.0
router rip
version 2
network 10.0.0.0
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
login
end
Router#show cdp neighbor
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
S - Switch, H - Host, I - IGMP, r - Repeater
Device ID Local Intrfce Holdtme Capability Platform Port ID
Router Ser 0/1 170 R 2621 Ser 0/1
Router Ser 0/0 170 R 2621 Ser 0/0
switch Fas 0/12 170 SI 2950 Fas 0/1
switch Fas 0/12 170 SI 2950 Fas 0/0
Router Con0 is now available
Press RETURN to get started!
Router>enable
Router#show ip protocols
Routing Protocol is "rip"
Sending updates every 30 seconds, next due in 14 seconds
Invalid after 180 seconds, hold down 180, flushed after 240
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Redistributing: rip
Default version control: send version 2, receive version 2
Interface Send Recv Triggered RIP Key-chain
Serial0/1 1 1 2
Serial0/0 1 1 2
FastEthernet0/1 1 1 2
FastEthernet0/0 1 1 2
Automatic network summarization is in effect
Maximum path: 4
Routing for networks:
10.0.0.0
Routing information sources:
Gateway Distance Last Update
Distance: <default is 120>
Router#show ip route rip
10.0.0.0/24 is subnetted, 4 subnets
Router#
This is the information of switch (Catalyst 2950):
switch#show running-config
Current configuration : 866 bytes
version 12.1
no service pad
hostname switch
ip subnet-zero
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface Vlan1
ip address 10.87.200.254 255.255.255.0
no ip route-cache
ip default-gateway 10.87.200.1
ip http server
line con 0
line vty 0 15
login
end
If something else is needed, please let me know. Thanks and regards.
Richard Burts Wed, 07/09/2008 - 10:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jorge
You have not given us any detail to work with to understand your situation and to identify your problem. I will make these suggestions but having better information about how the switch is set up would allow us to give you better answers,
- is this a layer 2 switch or a layer 3 switch?
- are you pinging from the switch itself or from a PC connected to a switch port/interface?
- if from the switch do you have a valid IP address configured on the management interface of the switch? does the switch have a valid default gateway configured?
- if from a PC do you have a valid IP address and mask configured on the PC? Is the default gateway configured on the PC and is it working?
- are you trying to ping something in your own subnet or is the destination in a remote subnet?
If you can clarify these things then perhaps we can find answers to your issue.
Rick
glen.grant Wed, 07/09/2008 - 14:48
  • Purple, 4500 points or more
The only way it would work right now is to have a single connection from the router to the switch from router interface F0/0 which is the subnet that the switch ip address is in .What ip address does your client have ? It would have to have a 10.87.200.x address if they are on the switch. Where do the switches hook to the router ? It also looks like everything on the switch is in vlan 1 so no other subnets would work . What you would have to do if you need to have multiple subnets would be to setup trunking on the router with subinterfaces and run a single link to the switch . You then would have to create vlans on the switch itself if you need more than 1 subnet on that same switch.
this might help with the trunking end .
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a00800949fd.shtml
