Restrict user to 1 IP (Remote access PPTP)
Answered Question
Jul 9th, 2008
Hi everyone,
I've setup remote access PPTP VPN on a 2801 router (running 12.4 advsecurity).
What I'm trying to do is restrict the VPN user to only one IP in the network. I'm having trouble finding out how to get that configured.
Here's my config:
aaa new-model
aaa authentication login default local
aaa authentication ppp default local
vpdn enable
vpdn-group PPTP
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
interface Virtual-Template1
ip unnumbered Serial0/1/0
peer default ip address pool PPTP_Pool
no keepalive
ppp encrypt mppe auto
ppp authentication ms-chap ms-chap-v2
ip local pool PPTP_Pool 172.16.0.50 172.16.0.60
Connecting to the VPN works just fine. I just need to know how to restrict the user to be able to access one IP in the network.
Thanks in advance!!!!!!
Correct Answer by singhsaju about 8 years 8 months ago
You can try using access list and bind it to inside interface (interface connected to your network) on the router as outbound.
Saju
Overall Rating: 5 (1 ratings)
Correct Answer
singhsaju Wed, 07/09/2008 - 13:08
  • Silver, 250 points or more
Saju
amiralisetoudeh Wed, 07/09/2008 - 15:24
Many thanks for the reply Saju. I assigned an access list to fa 0/0 and set the direction to 'out'.
It seems like it works... I just thought there might be a VPN related command that would perform the task.
Thanks again!
