FXS / FAX issue with 2821 router
rescueskier
I am having an issue setting up a fax machine connected to a VIC2-2FXS card. The issue is that when I dial in with the fax machine connected, it goes directly to a dial tone. If I dial 9 and a number I can place a call. (not the desired result) If I connect up a analog phone, it rings and I can answer and talk just fine.
For configuration, I am using IOS 12.4(19b) [I have tried various IOS version]
My clock settings are network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
Yes, this is a E1 line located in UK.
The port is:
voice-port 0/3/0
And the dial peer is:
dial-peer voice 120 pots
description Fax Machine
destination-pattern 980871
port 0/3/0
I am getting 6 digits from the provider so I am matching on all digits.
I am doing this in 3 other offices in US and it works fine, so I am stumped to what is wrong.
Attached it a debug of the q931 and dialpeer.
7 Replies 7
Chad Stachowicz
Level 6
Level 6
I think you need a station-id command under the voice-port... Also is this a 3G fax?
HTH, please rate useful posts
Chad
dvowell
Do you have direct-inward-dial configured on the inbound POTS dial-peer
Dave
Here is all my dial-peers.
dial-peer voice 201 voip
description call routing for incoming calls (subscriber)
preference 1
destination-pattern 98....
session target ipv4:172.30.9.2
dtmf-relay h245-alphanumeric
dial-peer voice 202 voip
description call routing for incoming calls (publisher)
preference 2
session target ipv4:172.30.9.1
dial-peer voice 100 pots
description Call Routing for Emergency
destination-pattern 9999
progress_ind setup enable 3
progress_ind connect enable 8
direct-inward-dial
port 0/0/0:15
forward-digits 3
dial-peer voice 103 pots
description call routing for international calls
translation-profile outgoing outgoing
destination-pattern 900.T
direct-inward-dial
port 0/0/0:15
prefix 00
dial-peer voice 104 pots
description Call routing for UK Mobile
destination-pattern 907[1-9]........
port 0/0/0:15
forward-digits 11
dial-peer voice 105 pots
description Call routing for Freephone (800 numbers)
destination-pattern 908T
port 0/0/0:15
prefix 08
dial-peer voice 101 pots
description Call routing for Local Dialing
destination-pattern 9020[2-9].......
direct-inward-dial
port 0/0/0:15
forward-digits 8
dial-peer voice 106 pots
destination-pattern 9[2-9].......
direct-inward-dial
port 0/0/0:15
forward-digits 8
dial-peer voice 110 pots
description Call Routing for Operator
destination-pattern 9100
port 0/0/0:15
forward-digits 3
dial-peer voice 111 pots
description Call Routing for Services
destination-pattern 91..
port 0/0/0:15
forward-digits 3
dial-peer voice 112 pots
destination-pattern 918..
port 0/0/0:15
forward-digits 4
dial-peer voice 113 pots
description Call Routing for Directory Services
destination-pattern 9118...
port 0/0/0:15
forward-digits 6
dial-peer voice 114 pots
description Call Routing for Childline
destination-pattern 908001111
port 0/0/0:15
forward-digits 8
dial-peer voice 115 pots
description Call Routing for NHS Direct
destination-pattern 908454647
port 0/0/0:15
forward-digits 8
dial-peer voice 116 pots
description Call routing for Freephone (500 numbers)
destination-pattern 905T
port 0/0/0:15
prefix 05
dial-peer voice 117 pots
description Call routing for National Dialing
destination-pattern 901[2-9]........
direct-inward-dial
port 0/0/0:15
forward-digits 11
dial-peer voice 1 pots
preference 1
incoming called-number .
direct-inward-dial
port 0/3/0
dial-peer voice 180 voip
description Catchall VoIP Dial Peer
voice-class codec 1
voice-class h323 1
fax rate disable
fax protocol pass-through g711ulaw
no vad
did you add that station-id command? Also enable fax-relay..
HTH,
Chad
I have added the command, but no change. This not a fax relay from router to router. The call is being received by ISDN/E1 line in the router itself. Also, it is a G3 fax, which I have disabled the G3 on.
can you hook me up witha debug voip ccapi inout
please..
Chad
Here is the voip ccapi inout debug
