Unable to access LAN on 871 EasyVPN Server
Jul 9th, 2008
I am new to Cisco equipment, so am using the 871W Router for learning. I used the SDM to setup the Easy VPN Server.
I can connect no problem using the Cisco VPN Client. However once connected, I am unable to access any of the resources. If I ping 10.5.1.30, my printer, it times out.
If I monitor the terminal I don't see anything. Looking at the statistics in the client, I see encrypted packets but no decrypted packets. It appears the request is being sent through the tunnel but not reaching the 10.5.1.0/24 network.
Attached is my configuration, any help is appreciated!
tahequivoice Thu, 07/17/2008 - 11:58
I wasnt able to see your config, the server is throwing errors, but when you set up the VPN for the remotes, did you setup a different pool of IP addresses for them? They should not be out of the same subnet of IP's.
ip local pool 10.5.2.1-10.5.2.254 netmask 255.255.25.0
I dont care too much for SDM since I have been using the CLI for over 10 years now. The SDM just confuses me. It is great however for troubleshooting.
