Chad Stachowicz Wed, 07/09/2008 - 12:11
  • Silver, 250 points or more
Of course you can! Just use cor lists if this is a CME. Essentially they are CSS/PT setup for CME/SRST. cciev.wordpress.com has some config examples. or searching cisco.com for corlist should find some stuff..
HTH, please rate useful posts..
Chad
Paolo Bevilacqua Wed, 07/09/2008 - 13:54
  • Hall of Fame,
    Founding Member
A simple way is a translation-profile incoming for ephone-dn
voice translation-rule 10
rule 1 reject /5551234/
voice translation-profile block
translate called 10
Please rate post if it helps!
