error message when removing a provision swtich from a catalyst3750
Jul 9th, 2008
this is a new switch and there is no other switches connected to it.
Two commands someho got in the configuration and I would like to take them out:
switch 1 provision ws-c3750g-24ts
switch 2 provision ws-c3750g-24ts
if I try to remove them, i get error:
ksfo510(config)#no switch 2 provision ws-c3750g-24ts
%IDBs can not be removed when switch is active
The show switch command shows that switch 2 is master so I suspect that I must make switch 1 master or somehow disable switch 2 logically.
ksfo510#show swit
Current
Switch# Role Mac Address Priority State
1 Member 001c.0ea1.5880 1 Ready
*2 Master 001c.0ea1.4c80 1 Ready
any ideas how to remove these commands from the config?
