Cisco ATA 188 with Fax
Jul 9th, 2008
Any idea on how to configure the cisco ATA 188 for fax? Cus I have problem sending and receiving fax, but I can make and received calls without problems.
I attach the cisco ATA configuration.
Overall Rating: 4 (2 ratings)
Ayodeji Okanlawon Wed, 07/16/2008 - 02:29
Your audio mode and connect mode settings are wrong...
Configuring the Cisco ATA for Fax Pass-through mode
Fax Pass-through mode requires configuring two configuration parameters:
AudioMode
ConnectMode
AudioMode
Description
The AudioMode parameter is a 32-bit value. The lower 16 bits apply to the Phone 1 port of the Cisco ATA and the upper 16 bits apply to the Phone 2 port of the Cisco ATA.
Your audio mode for fax pass throuhg for port1 of the ata should be
0xXXXX0015
and for port 2 of the ata 0x0015XXXX
Your connect mode settings should be...
ConnectMode
Description
The ConnectMode parameter is a 32-bit value. The parameter settings apply to both lines of the Cisco ATA. Configure ConnectMode after configuring AudioMode for fax pass-through mode. Cisco recommends you use the following ConnectMode setting to interoperate with a Cisco IOS gateway.
Recommended Setting
0x90000400
Alejandro Corte... Wed, 07/16/2008 - 07:22
Hi in this parameter:
"0xXXXX0015" the "X" must be "X" or it means that I should replace the "X" for another number?
Ayodeji Okanlawon Wed, 07/16/2008 - 02:21
You dont specify the cisco ATA in a dial-peer.
You configure the ATA in call manager and then you create a dial-peer with its destination-pattern as the directory number of the ATA and session target as callmanager IP address.
