Check to see if a file exists
Jul 9th, 2008
Is it possible to check to see if a prompt file exists, or to play a different .wav if the one listed is not there?
Scenario:
Play 1.wav if it exists
if 1.wav does not exist, play 2.wav
Robert
honniesr Tue, 07/15/2008 - 08:15
Irisrios,
That is for unity express, not Contact Center. Can we use that with it?
Robert
mmelbourne Wed, 07/16/2008 - 01:22
  • Silver, 250 points or more
You may be able to use the com.cisco.prompt.PromptException (or similar) exception in the "On Exception Goto" step around a "Play Prompt" step. This assumes that the absence of 1.wav will assert the exception.
I have successfully used the com.cisco.doc.DocumentException to detect the presence of an XML file in the Repository.
Please rate helpful posts.
honniesr Wed, 07/16/2008 - 21:32
I went through all of them com.cisco.prompt errors and nothing seemed to work. However, I had the prompt set to continue on errors. If is set it to "NO", the entire script stops and the caller hears a message about a system error.
Any ideas or pointers? :)
Robert
honniesr Wed, 07/16/2008 - 21:30
After I looked at the information closer, I see what you were trying to tell me. Sorry, I stopped when it said unity on the top :(
Anyways, when I tried following their example and set the prompt to not continue on errors (to throw the on exception flag), the script stops completely and the caller hears there has been a system error :(
Any ideas?
Robert
