config-register 2101 on Cisco 4507 issue
Jul 9th, 2008
Currentlt I have a Cisco 4507 has the following info.
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(40)SG, RELEASE SOFTWARE (fc2)
Technical Support:
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 07-Nov-07 18:51 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x117EBBE8
ROM: 12.2(31r)SGA1
Dagobah Revision 226, Swamp Revision 34
Switch uptime is 2 minutes
Uptime for this control processor is 2 minutes
System image file is "bootflash:cat4500-ipbasek9-mz.122-40.SG.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4507R-E (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOX1209GL5P
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
1 Virtual Ethernet interface
100 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Is the config-register 2101 correct ?
It should be 2102 ? any advise Thanks
lee.reade Wed, 07/09/2008 - 22:09
Yes you are correct, you want the config register to read 0x2102, a setting of 0x2101 will result in the router/switch booting into bootstrap mode when it reboot.
Bootstrap mode is used for you to run a mini IOS, when your main IOS image is corrupt, this lets you config an IP address so you can download a proper full image.
