IPS 4260 performance metrics
Jul 9th, 2008
Dear all,
In http://www.cisco.com/en/US/docs/security/ips/6.0/installation/guide/hw4260.html (Installing IPS 4260), the following is mentioned: The 1-Gbps performance for IPS-4260 is based on the following conditions: 10,000 new TCP connections per second, 100,000 HTTP transactions per second, average packet size of 450 bytes, and the system running IPS 6.0 software. The 1-Gbps performance is traffic combined from all sensing interfaces.
The information in the manual does not include the following metrics: number of simultaneous sessions (not just the new ones) and number of sessions per second.
Can you please provide me with this information? (1 Gbps performance in transactional environment)
th.stergiou Tue, 07/15/2008 - 21:09
thank you very much for the reply. The link indeed was more than helpful. Really appreciate this
