NBAR support on CAT 6509 -
Jul 9th, 2008
IS there a link which gives you the IOS version requirement and H/W requirement for a CAT6509 to provide NBAR Support?
Getting the following message:
CEF or distributed CEF switching is required for NBAR 'protocol discovery' command
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
(config)#int vlan 1
(config-if)#ip nba
(config-if)#ip nbar pro
(config-if)#ip nbar protocol-discovery
(config-if)#
CR6509-02(config-if)#
CR6509-02(config-if)#do sh run in vlan 1
Building configuration...
Current configuration : 399 bytes
interface Vlan1
description Default Router HSRP address
ip address x.x.x.x x.x.x.x
ip rip authentication mode md5
ip rip authentication key-chain RIP
ip route-cache flow
no ip mroute-cache
standby 1 ip x.x.x.x
standby 1 timers 5 15
standby 1 priority 110
standby 1 preempt
standby 2 ip x.x.x.x
standby 2 timers 5 15
standby 2 priority 110
standby 2 preempt
end
config-if)#ip c?
cef cgmp
(config-if)#ip ce
(config-if)#ip cef ?
accounting CEF accounting features for interface
(config-if)#^Z
#conf t
(config)#ip ce?
cef
(config)#ip cee
(config)#ip ce
(config)#ip cef ?
accounting Enable CEF accounting
distributed Distributed Cisco Express Forwarding
event-log CEF event log commands
interface CEF linecard commands
linecard CEF linecard commands
load-sharing Load sharing
nsf Set CEF non-stop forwarding (NSF) characteristics
table Set CEF forwarding table characteristics
traffic-statistics Enable collection of traffic statistics
------------------ show module ------------------
Mod Ports Card Type Model Serial No.
2 10 WiSM WLAN Service Module WS-SVC-WISM-1-K9 SAD112305DC
3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL10019DP8
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL09486HHM
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAD091402G9
8 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX SAD094900PA
9 48 48-port 10/100/1000 RJ45 EtherModule WS-X6148A-GE-TX SAL09475WDG
Mod MAC addresses Hw Fw Sw Status
2 001b.d57a.a760 to 001b.d57a.a76f 2.0 12.2(14r)S5 12.2(18)SXF4 Ok
3 0016.47d6.7d88 to 0016.47d6.7d9f 2.3 12.2(14r)S5 12.2(18)SXF4 Ok
5 0013.c42e.e678 to 0013.c42e.e67b 4.4 8.1(3) 12.2(18)SXF4 Ok
6 0011.5cab.56f8 to 0011.5cab.56fb 4.3 8.1(3) 12.2(18)SXF4 Ok
8 0016.4695.e690 to 0016.4695.e6bf 1.3 8.4(1) 8.5(0.46)RFW Ok
9 0016.4669.8d50 to 0016.4669.8d7f 1.1 8.4(1) 8.5(0.46)RFW Ok
Mod Sub-Module Model Serial Hw Status
2 Centralized Forwarding Card WS-SVC-WISM-1-K9-D SAD112303B7 2.0 Ok
3 Centralized Forwarding Card WS-F6700-CFC SAL10019C7V 2.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAL09486J9D 2.1 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL09486KD6 2.3 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAD09110CR3 2.0 Ok
6 MSFC3 Daughterboard WS-SUP720 SAD091300GS 2.3 Ok
Overall Rating: 4 (3 ratings)
astanislaus Wed, 07/09/2008 - 22:58
What are the warnings we should give customer if we get NBAR working? Should we warn customer about CPU spikes? Will packets get process switches on those interfaces with NBAR enabled.
lee.reade Wed, 07/09/2008 - 23:03
You can use the feature navigator to verify what version you need to enable this,
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Just search by feature and then select platform, 6500 sup720 from list,
However, since you are on sup7203b, you will almost defo have it already, just enable cef, with ip cef command,
If not then have a look at FN.
LR
