calls getting disconnected when going over E1 PRI QSIG to Avaya PBX
Jul 10th, 2008
I am implememnting the integration of call manager 6.1 to Avaya Definity G3R PBX.After the configuration when a call is placed from Avaya to Cisco it goes through but when a call is placed from cisco to avaya i get this message.
*Jul 10 08:01:49.503: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8 callref = 0x0001
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Facility i = 0x9FAA06800100820100A112020100020100800A4964726973204D757361
Calling Party Number i = 0x0081, '6357'
Plan:Unknown, Type:Unknown
Called Party Number i = 0x80, '326'
*Jul 10 08:01:49.543: ISDN Se0/0/0:15 Q931: RX <- RELEASE_COMP pd = 8 callref = 0x8001
Cause i = 0x81D8 - Incompatible destination
indly help sort out this problem because it is having a serious (critical )delay in business
tomide_ccie Thu, 07/10/2008 - 06:23
try this:
isdn switch-type primary-dms100
isdn protocol-emulate network
isdn incoming-voice voice
isdn T306 60000
isdn bind-l3 ccm-manager
you may need to change the pri protocol if avaya doesn't support dms100, the configuration above is for Nortel, i had same issue and this config fixed it.
andrejrudas Thu, 07/10/2008 - 07:33
What device terminate ISDN on other side from Avaya?
If it is some cisco device check your pots dial-peer configuration, and try "no digit-strip".
