VPN and VLANs
Jul 10th, 2008
Hi folks,
I need your assistance on this...
We are using a PIX 515e firewall on the edge of our network.
Behind it a network, separated into VLANs (VLAN x has IP addresses
10.0.x.0/24 with x=11 to 17). Routing between VLANs is performed by
a layer-3 routing switch which is directly connected to the PIX, untagged in
VLAN 13 (IP address 10.0.13.254). Default gateway for network hosts
is the IP address of the routing switch in the VLAN, which the host
belongs to (i.e. 10.0.x.1 with x=11 to 17). Default route on the routing
switch points to the PIX, the PIX has routes back to the routing switch
for each of the IP ranges 10.0.x.0/24.
Now, recently, in came the remote access VPN capability of the PIX:
some users require access to the lan from their homes. Now i wanted to
"extend" the IP ranges defined by the VLANs over the VPN, meaning:
a user whose computer resides in VLAN x when he/she's in the office
(i.e. the host will have an IP address in 10.0.x.0/24) should receive
an IP address in 10.0.x.0/24 for the home workstation as well, once
the VPN tunnel is set up. The VPN should extend the LAN to the home
in its broadest sense, i.e. apart from the user setting up the tunnel with
the VPN client, the LAN should be fully transparent from home and
the home user's perception should be as if he/she were in the office.
Now i'm far from an expert in this matter, hence this post...
Can this be achieved with the above preliminaries (for other subnets than
10.0.13.0/24 as well)? How do i tackle this (also if not possible with the
above assumptions)? Can i use DHCP? Do i need to tag the link between the routing switch and
the PIX on all VLANs (in that case, assuming i want the routing switch to
keep doing the routing, how do i configure the routing on the routing switch
and on the PIX)?
Thanx in advance for your replies,
Tim
