Hunt Group to work up until specific time!
Jul 10th, 2008
Hi All,
Just a quick query to ask, does anybody have any suggestions on how to manipulate a hunt group to only work for a specific time.
Scenario: Group of extensions that have a call fwd when busy / no answer on their UDP profiles to the hunt pilot. This works 24 hours a day. Now wish for the hunt group to stop working after 6pm and any calls for an extension goes “straight” to voicemail…
I'm thinking along the lines of putting my hunt pilot in a partion with time periods / schedules created.
Any ideas?
Thank you
Jaime Valencia Thu, 07/10/2008 - 05:35
  • Cisco Employee,
  • Hall of Fame,
    2011
i believe you have a duplicate of this (please do not do so) and the answer is the same as the other one TOD is what you're looking for.
javalenc
if this helps, please rate
